Date/Time: Wed, 01 May 2024 21:01:48 +0000
Rithmic Service - Seconds bar Charts presentes 1min bar history ---- only after that presents 30
View Count: 2111
[2014-04-01 18:55:39] |
pedro.gomes - Posts: 13 |
Hello, I have Rithmic tradind service with Sierra. When I put the bar period to seconds, for example 30s, the chart appears with 1min bars, and only after that it starts to present 30s bars. All intraday history is presented with 1 minute bars. happends with differente futures symbols. Tried with intraday data storage 1sec or 1 tick. Can you help please. I hope there is no limitation what so ever for bar charts with seconds for Rithmic service... Can send printscreen if necessary. Pedro Gomes Date Time Of Last Edit: 2014-04-01 18:56:35
[2014-04-01 19:18:40] |
For historical tick by tick data when using Rithmic you will need to use the Sierra Chart Exchange Data Feed: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Otherwise the history is 1 minute. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-01 19:28:20] |
Hello, I already pay for Rithmic Data/trading service (inserted in commissions fee). They don't have seconds bar history ??? So you are telling me that to have seconds bar history I have to pay additional 35$ to SC for CME Feed ? Thank you Pedro Gomes |
[2014-04-01 19:57:43] |
Yes, this is all correct.
[2014-04-01 20:40:24] |
Hi last question... does the same happends with CTS ? Thank you PG |
[2014-04-01 20:51:14] |
Carl71 - Posts: 125 |
Hi
last question... does the same happends with CTS ? Thank you PG No. http://www.sierrachart.com/index.php?l=doc/CTS_T4.php |
[2014-04-01 20:59:53] |
CTS has historical tick by tick data.
[2014-04-01 22:12:00] |
So you are saying that since CTS as tick by tick they will provide seconds bar chart intraday history. O need for Sierra Charts CME data Feed. Rithmic don't provide tick by tick data so Sierra Charts can't use this data and charts come with 1min bar instead of seconds bar, and I need Sierra charts data feed. Yes ? PG Date Time Of Last Edit: 2014-04-01 22:12:34
[2014-04-01 23:09:35] |
Sawtooth - Posts: 3987 |
Optimus Futures offers Rithmic with historical tick data, because they collect their own.
[2014-04-01 23:26:56] |
In the case of CTS, you will not need to use the Sierra Chart Data Feed, unless you want to. CTS does provide historical tick by tick data. In the case of Rithmic, there is only 1 minute historical data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-01 23:27:25
