Date/Time: Fri, 06 Nov 2026 09:06:09 +0000
Candles not plotting
View Count: 833
| [2021-11-17 18:13:15] |
| User417723 - Posts: 19 |
The candles are not plotting. Please refer to the attached chart. Price is below where the candles last plotted. This has been a common occurrence. Please advise. Thank you. |
| [2021-11-17 18:54:48] |
| John - SC Support - Posts: 48449 |
Refer to the following (in particular, the section regarding the Lock Fill Space): Working With Charts: Scrolling The Chart and Right Side Fill Space We also want to point out that you are getting Delayed Data. If this is not your intent, then let us know where you want to get your real-time data from (us or your trading service) and we can help you get setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
