Date/Time: Sun, 01 Nov 2026 11:51:05 +0000
Using Market Depth Historical Graph with Transact
View Count: 945
| [2021-11-17 14:15:07] |
| User361939 - Posts: 170 |
Hi, i am user of Transact Data feed. I would like to use study "Market Depth Historical Graph" but after applying it on chart i got result (at the attachment) Am i doing something incorectly? How can get result of HeatMap as in screenshoot number 2 (screen is not from Sierra, but i hope you get a picture) Best Regards |
| [2021-11-17 14:27:57] |
Only the Denali Exchange Data Feed provides the proper data for this feature. You need to use the Denali Exchange Data Feed for data: Denali Exchange Data Feed And you also need to activate the relevant CME exchange based on the symbol you require data for, which provides market depth data. And for order routing we recommend using the Sierra Chart Teton Futures Order Routing service: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-17 14:30:33
| [2021-11-17 15:12:58] |
Would you be kind and said if with transact i can get result mentioned above or at least simmilar? I got information that their data works with this studie. Best Regards |
| [2021-11-17 15:26:53] |
The answer is no. And support for Transact is going to be discontinued at the end of 2021. So you need to move to a different service anyway. This is what we recommend: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-17 15:27:39
| [2021-11-17 15:36:09] |
TY for information: To sumup for me: Starting 2022. I can only use TRANSACT AS MY BROKER (transaction) I HAVE TO USE DATA from e.g Denali or something you recommended.(data) Are those statements correct? Best Regards Date Time Of Last Edit: 2021-11-17 15:49:42
| [2021-11-19 20:21:55] |
| Sierra_Chart Engineering - Posts: 25339 |
We are planning to remove support for Transact completely. You will need to use the Denali Data Feed at the very least: Denali Exchange Data Feed For order routing, Ninja/Transact has said they will be supporting CQG. So you could use CQG or our direct order routing. We will definitely recommend our direct order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-19 20:22:35
