Date/Time: Fri, 06 Nov 2026 08:53:19 +0000
Sierra/Denali
View Count: 806
[2021-11-15 15:25:37]
User679462 - Posts: 1
I would like to connect Sierra/Denali to my AMP account. AMP support refers me to Sierra. Can you help me?
[2021-11-15 17:05:25]
The specific instructions you need will depend on what Order Routing service you are setup to use with AMP.
If you are setup with Rithmic, then you will follow these instructions:
Rithmic Trading Platform Service: Setup Instructions
Otherwise, if you are setup with CQG, then you will follow these instructions:
CQG Trading Platform Service: Setup Instructions
Separately, we notice that you are on Package 12, but you do not have any exchanges active on the Denali Exchange Data Feed. If you are wanting to use the Denali Exchange Data Feed, then you will need to go through all of the instructions at the following link:
Otherwise, if you are not wanting to get data from us, then you do not need to be on Package 12. If you are using CQG, then you can be on Package 3 or 5, but if you are using Rithmic, then you need to be on Package 10 or 11.
