Date/Time: Sun, 12 May 2024 08:55:51 +0000
YM-201406-ECBOT [CB] [M] missing data between 2013-03-11 -2013-03-31
View Count: 957
[2014-04-01 08:18:49] |
User51173 - Posts: 3 |
I have SC real-time data with Interactive Brokers trading. If I open YM-201406-ECBOT then the data between 2013-03-11 and 2013-03-31 are missing. The Continuous Contract is set-up to Continuous Futures Contract - Date Rule Rollover, Back Adjusted [CB]. See screenshot http://www.sierrachart.com/image.php?l=1396339207695.png Other contracts like ES and NQ are OK. Thank you. Date Time Of Last Edit: 2014-04-01 08:41:22
[2014-04-01 08:41:09] |
Refer to help topic 7.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails7.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-01 08:42:25] |
Disregard the prior post, refer to this section here about re-downloading the missing data: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-04-01 08:42:33
