Date/Time: Sun, 12 May 2024 06:39:18 +0000
New Install File Transfer
View Count: 946
[2014-04-01 05:01:54] |
Profile Trader - Posts: 168 |
I completed a new install and was able to transfer all my files and settings over except my "customize chart shortcut menu" I completed the transferring sc settings and data from existing installation to new installation documentation. Is there another file not listed that holds this settings? Thanks, Doug |
[2014-04-01 06:03:46] |
Did you copy over the Sierra3.CFG file? This file should be copied to the destination folder when Sierra Chart is not running.
[2014-04-01 12:01:34] |
Yes I did.
[2014-04-01 13:41:32] |
I recopied everything again and I have it now. I must have done something wrong. Thanks, Doug |
