Date/Time: Tue, 30 Apr 2024 16:06:45 +0000
Trading Dom Notes Column
View Count: 2881
[2023-11-07 19:13:59] |
User692899 - Posts: 1 |
+1 definitely need this, weird how you can customize literally everything else and tweak your ladders more than any other ladder software out there yet it misses this simple feature. YES PLS!
[2023-11-07 19:14:47] |
User130077 - Posts: 9 |
This is something I would really get value from, please update if you look to add this feature
[2023-11-08 00:05:14] |
User191029 - Posts: 6 |
+1 on this FRQ
[2023-12-17 04:38:17] |
User989376 - Posts: 1 |
Really want this feature!
[2023-12-28 14:08:48] |
User440951 - Posts: 37 |
I would also like this very useful feature ! Could you plan to add it ? A simple column in the DOM columns
[2023-12-28 16:35:16] |
widget - Posts: 4 |
+1 on this FRQ
[2023-12-28 17:12:18] |
User879838 - Posts: 32 |
+1
[2023-12-28 18:42:58] |
User714169 - Posts: 3 |
Please add this feature.
[2023-12-28 21:04:17] |
User929353 - Posts: 15 |
I think this would be excellent.
[2023-12-29 01:55:07] |
bocho - Posts: 1 |
I would certainly utilize this if implemented
[2023-12-29 02:42:00] |
User48838 - Posts: 112 |
+1 ty
[2023-12-29 02:43:59] |
AlinGA - Posts: 14 |
+1 ty
[2024-01-30 05:02:49] |
alphawave - Posts: 1 |
+1 thanks!
[2024-02-01 14:12:55] |
Pacurar Radu Andrei - Posts: 2 |
+1 thanks!
[2024-02-02 16:36:03] |
User153286 - Posts: 44 |
SUCCESS! You can do this today using Hot Keys Hey Sierra could you please put the Tools menu on the DOM Pre-Setup Steps --------------- 1.) Set your default text options Follow standard tool option configuration steps From any other regular chart that displays the Tools menu do the following Tools-> tools config - > text config - > options I only set color, there are other options to use 2.) Add a Volume Profile to your DOM - this is the key step From the DOM use the Chart menu Chart->Studies (F6) Add the Volume by Price study Configure as you like I belive any added DOM Chart study can be used as they are displayed in a column on the left side of the DOM Using the Volume Profile provides ample space in the most left column to add text of interest which is the goal Know these hot keys (you can see these from any Tool menu) ----------------------------------------------------------- Cursor alt 1 pointer alt 3 cross hair alt h hand Type Text (this gets stuck to price not stationary on screen) ctrl y Type Text, this text tool get stuck to a price Do not use Stationary Text - this text tool gets stuck to the screen location Remove Text alt shft T removes text Instructions ------------- 1.) Put mouse in pointer mode (alt 1) and move to Volume Profile location of interest on DOM - any mode works but pointer seems best to me on DOM 2.) Press Control Y to activate the Type Text tool. 3.) Move mouse to location of interest within the Volume Profile area 4.) Click mouse to bring up text entry dialog and enter text, follow instructions on prompt 5.) The text will appear at the mouse-pointer location on Volume Profile and will stay with the price row as you move up and down on the DOM Because of the Control Y hotkey, the Type Text tool is active. If you click on the Volume Profile area again, it will again pop up the text entry dialog. This clicking action only works in the Volume Profile (DOM Chart Study column), the other columns on the DOM are un-affected and work as expected. For example you can still click to enter a Buy of Sell entry. Maybe Sierra might want to add this to their documentation. |
[2024-03-27 18:08:22] |
Lorne McConnachie - Posts: 7 |
+1 on this. Would be super efficient if we could click and type on a DOM column to quickly notes for what we see on the DOM |
