Date/Time: Mon, 29 Apr 2024 07:31:55 +0000
Accumulated Volume & Daily Percent
View Count: 2479
[2013-04-24 12:13:57] |
johnson2626 - Posts: 14 |
I was looking at and played around with various studies in the recent days; I am quite new to charting financial markets so please bear with me if I am not familiar with common study names or methods to display certain things. I was looking for the following displays but had no luck in finding them or setting them up: - Accumulated Volume by Price I found the Volume by Price study which can be set up to display the volume by a specific price range. I was wondering if there is a way to have an accumulated value: At the lowest tick the volume would be 100% of the total volume traded, at $10 it would add all trades between $0 and $10, etc. Is this possible with existing studies? - Daily Percent win/loss I was looking for a way to display the daily percent gain/loss compared to the previous trading day (or other periods of time, generally i'd be interested in 24h sections to compare the gain/loss by price in percent compared to the previous days close (for BTC 23:59) or possibly even for the daily average. Any study for that? Thanks in advance |
[2013-04-25 03:27:44] |
1. We are not really clear about the first question. We can only refer you to the functionality we offer. Please look at the Volume by Price documentation: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html 2. Use the Percent Change Since Open study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s325 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
