Date/Time: Fri, 06 Nov 2026 08:47:01 +0000
HKEX
View Count: 1511
[2021-11-08 15:07:12]
User76183 - Posts: 69
Hello! Currently I have Denali datafeed and CQG order-routing with AMP.
I'd like to trade HKEX contracts too, but I don't want to change Denali as I have been trading CME.
How can I set up HKEX additionally?
[2021-11-08 16:11:05]
We have data for the Hong Kong Futures Exchange, which is part of the HKEX. You can get this data from the Sierra Chart Exchange Data Feed. For information, refer to the following (which also includes Setup Instructions):
Otherwise, you could get the data from CQG for the HKEX data.
[2021-11-08 16:49:59]
I see...But in that case I wil need to switch to Sierra Chart Exchange Data Feed ( there is no CME there). Now I have Denali data, but actually my connection is CQG Web API (because of order-routing). How can I keep both datafeeds connected at the same time and keep CQG Web API for the execution?
[2021-11-08 17:18:44]
This is not a problem, this is how Sierra Chart is built. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed
