Date/Time: Fri, 06 Nov 2026 08:47:05 +0000
Continuous Futures Contract - Rollover Each Year. Same Month
View Count: 1049
[2021-11-06 21:09:27]
User146848 - Posts: 124
Greetings,
do i understand it correctly? The current month may be november, so every prior year is represented by the november contract and only by this single contract.
If there is a december contract next month, then all prior years will be shift to their december contract.
The chart should be merged toghether like nov19-nov20-nov21 and then dec19-nov20-nov21.
Is this right?
Date Time Of Last Edit: 2021-11-07 18:33:28
[2021-11-07 16:03:02]
You have the general idea correct, but not all symbols have contracts every month. You would need to look at the exchange information for a particular symbol to see how the contracts are laid out and when they expire.
For some more general information, refer to the following:
Continuous Futures Contract Charts
[2021-11-07 17:36:26]
Yes, i know.
What exactly is this kind of continuous contract trying to achieve, what others fail to do?
[2021-11-07 18:22:06]
It gives you a way to view historical data for a particular symbol over a time period longer than one contract.
[2021-11-07 18:34:20]
Hm...but isnt this the general purpose of any continuous contract method?
[2021-11-08 14:53:50]
Yes.
We are not understanding what you are wanting to know. What exactly is your question?
[2021-11-08 15:35:46]
My question is: What is this specific continuous contract method trying to achieve compared to a simple continuous method, where contracts get attached one after another?
As i understand, this method only has one contract per year, depending on the current active month. Thats different from having every most active contraced in timely order...Why...what the specific goal?
[2021-11-08 16:54:51]
First of all, we took another look at your first post and we did not notice what you had stated regarding the contracts. With the Continuous Futures Contract you do not get just the one contract for the previous years. You get the previous contracts strung together over the course of the years. Therefore, if the contracts were monthly you would have the following:
Jul21 - Aug21 - Sep21 - Oct21 - Nov 21
So, this is just a "simple" continuous contract if you want to call it that. We do have back-adjusting as well if you do not want to see a gap where the contracts switch over.
No, sorry we did not see this originally. See our note above.
