Date/Time: Sat, 14 Nov 2026 17:43:42 +0000
how to connect an AMP Futures account?
View Count: 2369
| [2021-11-04 23:30:03] |
| User845261 - Posts: 7 |
hi, How to connect an AMP Futures account? They have Sierra - denali - CQG (no data routing only) option. I have turned on this option. I set up the data feed on CQG Web Api and I have MBO data and can place orders. Is this correct? |
| [2021-11-05 00:10:30] |
| John - SC Support - Posts: 48527 |
In order to connect your Sierra Chart to CQG, you need to go through the Setup Instructions at the following link: CQG Trading Platform Service: Setup Instructions Make sure that you have done everything in there to ensure that you are fully setup. In terms of your setup for the Denali Exchange Data Feed, everything looks good. If you are having an issue getting the data for the CME Group, then let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-10-11 17:47:51] |
| AndyJMorris - Posts: 20 |
hi, Do I still need to link my AMP account with Sierra? I want the full Denali data feed for Futures and equities. Thanks |
| [2023-10-11 18:00:28] |
If you are wanting data from our Denali Exchange Data Feed for the CME Group, then we highly recommend connecting to your AMP account in order to qualify for the "Non-Professional" exchanges. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
