Date/Time: Sat, 11 May 2024 07:19:43 +0000
Intraday historical data
View Count: 908
[2014-03-31 14:28:55] |
User42392 - Posts: 5 |
Hello, I recently switched data providers from transact to CTS. With transact I was able to see intraday data back to 2006. With CTS I am only able to see intraday data for the past few contract months. What steps can I take to get data like I had with transact? |
[2014-03-31 16:20:52] |
We will have this problem solved , hopefully by Tuesday or Wednesday of this week. We will be adding support for expired futures contracts with CTS and they will go back to 2010. This will require Sierra Chart package 3 or 5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-31 17:49:16] |
Where can I go to buy intraday historical data that will be supported by sierra charts? Looking for as far back as the 1980's for bonds and notes
[2014-03-31 17:55:17] |
Have a look at the Sierra Chart Historical Data service and see if you can get data back that far for the particular symbols that you want: https://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
