Date/Time: Thu, 02 May 2024 10:38:25 +0000
[Locked] - unable to open $PCSX chart
View Count: 1472
[2022-11-08 23:11:56] |
AndyB - Posts: 96 |
Thank you. There are countless other symbols that don’t work either. You should tell them to double check all of their symbols in that data feed.
[2022-11-09 13:21:23] |
Sierra_Chart Engineering - Posts: 14173 |
Just tell us one or two other symbols and we will have them check on those.
[2023-01-06 23:42:26] |
User223498 - Posts: 10 |
Any update on this? It doesn't work for me either. No data loads.
[2023-01-07 00:51:33] |
User300216 - Posts: 7 |
same blank charts
[2023-03-11 05:54:27] |
GravisHTG - Posts: 303 |
is this fix ? It does not work for me either , do we need a special Data plan like NASDAQ ? its in index others Date Time Of Last Edit: 2023-03-11 05:57:00
[2023-03-13 15:47:46] |
John - SC Support - Posts: 31293 |
We need to know the exact symbols for which you are not getting the chart(s).
