Date/Time: Sat, 11 May 2024 05:05:18 +0000
TPO for USDX not plotting correctly after the weekend
View Count: 961
[2014-03-31 12:58:43] |
BJV - Posts: 29 |
The TPO prints correctly on Friday's trade however when I reconnect to the data feed on Monday's I lose lose Fridays profile. Friday's date also does not show My timezone is GMT +8hrs, I have the SC real live data feed connected to OEC. I have included an image of the last 10 trading days for the USDX to highlight how Fridays TPO prints after reconnecting, including the date changes e.g. 3-23; 3-30 |
SC TPO USDX.png / V - Attached On 2014-03-31 12:55:46 UTC - Size: 90.24 KB - 327 views |
[2014-04-01 04:41:05] |
Remove the TPO Profile Chart study from the chart. Do you see the chart bars for Friday 28th?
[2014-04-01 10:28:46] |
BJV - Posts: 29 |
Looking at the candles and referencing the TPO example above the session time is 16.00.00 - 03.59.59 and I have no data from 3-28 03.59, data kicks back in 3-31 02.20. When I set the chart session times to 06.00.00 - 05.59.59 I have no data from 3-28 05.59.59 - 03-31 02.20. I do not understand why I am not getting (or loosing) data from Friday mornings after I reload the chart on Monday's. I am watching the TPO build on Friday evening which indicates the data is there. In the above example I would expect data to load up to 3-29 05.00 in line with the the 6E....thanks |
[2014-04-01 17:52:05] |
Looking at the candles and referencing the TPO example above the session time is 16.00.00 - 03.59.59 and I have no data from 3-28 03.59, data kicks back in 3-31 02.20. This makes sense since you are filtering out that data with these Session Times.If there is missing data in the chart, then follow the instructions in help topic 7.1 here: https://www.sierrachart.com/index.php?l=doc/helpdetails7.html This is the data that we see using a +8 UTC time zone: http://www.sierrachart.com/image.php?l=1396374681124.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
