Date/Time: Mon, 13 May 2024 01:33:46 +0000
Displaying Sessions on chart
View Count: 982
[2014-03-31 08:30:24] |
Dom7364 - Posts: 257 |
Is there a way to display (with a vertical line for example), various sessions on a current chart? |
[2014-03-31 08:51:45] |
You can use the "Time Line" study.
[2014-03-31 08:56:18] |
Sure, but I meant automatically, with correponding sessions names et corresponding times etc? |
[2014-03-31 09:13:45] |
The closest Sierra Chart has would be the Vertical Grid: https://www.sierrachart.com/index.php?l=doc/doc_ChartMenu.html#Vgrid Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
