Date/Time: Fri, 06 Nov 2026 08:40:02 +0000
Can't connect to data
View Count: 904
[2021-10-29 15:13:28]
GPM2000 - Posts: 22
I'm unable to connect to my data.
I have Denali data, trading connected to One Up Rithmic.
I don't know if I was disconnected due to funds in my account originally. I have topped up my account and there are sufficient funds now, but I still can't connect to any data
Thank you
[2021-10-29 16:06:25]
Everything on your account looks good.
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2021-10-29 16:31:55]
GPM2000 - Posts: 22
Software version: 2315 64-bit | 2021-10-29 12:28:49.059
OpenGL enabled (NVIDIA Corporation/NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2) | 2021-10-29 12:28:49.061
Primary Thread ID: 10812 | 2021-10-29 12:28:49.061
Usage end date: 2021-12-14 | 2021-10-29 12:28:49.061
Enabled for: Advanced Features 2. | 2021-10-29 12:28:49.061
Enabled for: Sierra Chart Historical Data Service. | 2021-10-29 12:28:49.061
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-10-29 12:28:49.061
Enabled for: Delayed Denali Exchange Data Feed. | 2021-10-29 12:28:49.061
Enabled for exchange2: CME (Trading Account Required) | 2021-10-29 12:28:49.061
Enabled for exchange2: CBOT (Trading Account Required) | 2021-10-29 12:28:49.061
Enabled for exchange2: COMEX (Trading Account Required) | 2021-10-29 12:28:49.061
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-10-29 12:28:49.061
Enabled for exchange2: fairx_exchange.data | 2021-10-29 12:28:49.061
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-10-29 12:28:49.061
Current selected Data/Trading service: Rithmic Direct - DTC | 2021-10-29 12:28:49.061
Custom symbol settings values: enabled | 2021-10-29 12:28:49.061
Chart Update Interval: 500 | 2021-10-29 12:28:49.061
Intraday Data Storage Time Unit: 0 | 2021-10-29 12:28:49.061
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-10-29 12:28:49.061
2021-10-29 16:28:49 Local computer time in UTC | 2021-10-29 12:28:49.061
2021-10-29 12:28:49 Local computer time in SC Time Zone | 2021-10-29 12:28:49.061
2021-10-29 14:49:24 Server time in UTC | 2021-10-29 12:28:49.061
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-10-29 12:28:49.061
Program path: C:\SierraChart3\ | 2021-10-29 12:28:49.061
Data Files path: C:\SierraChart3\Data\ | 2021-10-29 12:28:49.061
OS Version Number: 10.0 | 2021-10-29 12:28:49.061
Locale Setting: C | 2021-10-29 12:28:49.061
DLLs: sst_ateam_64.dll, SST_ATEAM_RX_64.dll, sst_FreeBundle_64.dll, UserContributedStudies_64.dll | 2021-10-29 12:28:49.061
Allowed protected custom studies: SST_ATEAM, SST_ATEAM_PS, SST_FreeBundle | 2021-10-29 12:28:49.061
File >> Disconnect selected. | 2021-10-29 12:28:55.622
DTC Client socket (0) | CloseSocket call. | 2021-10-29 12:28:55.622
Rithmic Direct - DTC | Disconnected. | 2021-10-29 12:28:55.623
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 12:29:06.473
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 12:29:06.475
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 12:29:06.475
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 12:29:06.475
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 12:29:06.475
Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 12:29:06.573
Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 12:29:06.573
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 12:29:06.573
Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 12:29:06.573
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 12:29:06.663
DTC Client socket (1) | CloseSocket call. | 2021-10-29 12:29:06.683
DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 12:29:06.683
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 12:29:06.683
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:06.683
DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 12:29:06.756
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 12:29:06.756
DTC Client socket (1) | Closed. | 2021-10-29 12:29:06.756
WSACleanup called. | 2021-10-29 12:29:06.929
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 12:29:06.929
DTC Client socket (0) | CloseSocket call. | 2021-10-29 12:29:06.929
Rithmic Direct - DTC | Disconnected. | 2021-10-29 12:29:06.930
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:06.930
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 12:29:11.118
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 12:29:11.120
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 12:29:11.121
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 12:29:11.121
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 12:29:11.121
Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 12:29:11.218
Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 12:29:11.219
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 12:29:11.219
Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 12:29:11.219
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 12:29:11.307
DTC Client socket (1) | CloseSocket call. | 2021-10-29 12:29:11.318
DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 12:29:11.319
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 12:29:11.319
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:11.319
DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 12:29:11.400
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 12:29:11.400
DTC Client socket (1) | Closed. | 2021-10-29 12:29:11.400
WSACleanup called. | 2021-10-29 12:29:11.519
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 12:29:11.528
DTC Client socket (0) | CloseSocket call. | 2021-10-29 12:29:11.529
Rithmic Direct - DTC | Disconnected. | 2021-10-29 12:29:11.529
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:11.529
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 12:29:15.700
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 12:29:15.702
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 12:29:15.702
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 12:29:15.702
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 12:29:15.702
Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 12:29:15.869
Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 12:29:15.869
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 12:29:15.869
Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 12:29:15.869
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 12:29:15.939
DTC Client socket (1) | CloseSocket call. | 2021-10-29 12:29:15.962
DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 12:29:15.962
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 12:29:15.962
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:15.962
DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 12:29:16.032
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 12:29:16.032
DTC Client socket (1) | Closed. | 2021-10-29 12:29:16.032
WSACleanup called. | 2021-10-29 12:29:16.209
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 12:29:16.210
DTC Client socket (0) | CloseSocket call. | 2021-10-29 12:29:16.210
Rithmic Direct - DTC | Disconnected. | 2021-10-29 12:29:16.210
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:16.210
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 12:29:20.425
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 12:29:20.427
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 12:29:20.427
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 12:29:20.427
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 12:29:20.428
Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 12:29:20.545
Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 12:29:20.545
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 12:29:20.545
Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 12:29:20.545
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 12:29:20.615
DTC Client socket (1) | CloseSocket call. | 2021-10-29 12:29:20.615
DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 12:29:20.615
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 12:29:20.615
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:20.615
DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 12:29:20.708
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 12:29:20.708
DTC Client socket (1) | Closed. | 2021-10-29 12:29:20.708
WSACleanup called. | 2021-10-29 12:29:20.812
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 12:29:20.813
DTC Client socket (0) | CloseSocket call. | 2021-10-29 12:29:20.813
Rithmic Direct - DTC | Disconnected. | 2021-10-29 12:29:20.813
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:20.814
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2021-10-29 12:29:25.007
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2021-10-29 12:29:25.009
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2021-10-29 12:29:25.010
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-10-29 12:29:25.010
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2021-10-29 12:29:25.010
Rithmic Direct - DTC | Network connection to server complete. | 2021-10-29 12:29:25.104
Rithmic Direct - DTC | Starting socket receive thread. | 2021-10-29 12:29:25.104
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2021-10-29 12:29:25.104
Rithmic Direct - DTC | Sending logon request message. | 2021-10-29 12:29:25.104
DTC Client socket (1) | Socket gracefully closed by remote side. | 2021-10-29 12:29:25.196
DTC Client socket (1) | CloseSocket call. | 2021-10-29 12:29:25.202
DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-10-29 12:29:25.202
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-10-29 12:29:25.202
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:25.202
DTC Client socket (1) | Write has completed. Shutdown being performed. | 2021-10-29 12:29:25.300
DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-10-29 12:29:25.300
DTC Client socket (1) | Closed. | 2021-10-29 12:29:25.300
WSACleanup called. | 2021-10-29 12:29:25.425
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2021-10-29 12:29:25.426
DTC Client socket (0) | CloseSocket call. | 2021-10-29 12:29:25.426
Rithmic Direct - DTC | Disconnected. | 2021-10-29 12:29:25.427
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-10-29 12:29:25.427
[2021-10-29 16:36:22]
GPM2000 - Posts: 22
Thanks, connection restored
[2021-10-29 16:45:43]
We have heard back from Rithmic and they state that they have fixed the issue.
