Date/Time: Fri, 03 May 2024 08:18:24 +0000
Data Feed Requirements when using AMP
View Count: 1014
[2014-03-29 23:33:25] |
User60365 - Posts: 14 |
So through AMP (Level 5)I have two choices. Rithmic with no history or TT with inaccurate Bid/Ask volume. So if I want to execute via Rithmic or TT, but use SC data what steps would I all be required to do? Going through the information on the site it is all a little unclear. Would I be required to open a direct SC account as well as my AMP one and utilize two copies of SC? What packages would I require?
[2014-03-30 03:55:22] |
You need a direct Sierra Chart account. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html You do not need to use the AMP provided Sierra Chart account. And you need to use this data feed: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php You do not need two copies of Sierra Chart. Package 3 will be fine. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-30 12:52:38] |
So is this correct: $40/month Direct Account Level 5 Package (Need Numbers Bars) $35/Month Data Feed Plan $4/Month CME ($15.75/Month if I want Market Depth) For a total of $79/Month |
[2014-03-30 17:36:54] |
Yes.
