Date/Time: Sun, 05 May 2024 03:12:33 +0000
IB Trade Service: CME Group Micro Treasury Yield Futures not available
View Count: 722
[2021-10-24 11:36:36] |
User542502 - Posts: 16 |
There is no symbol translation for the new Micro Treasury Yield Futures for the Interactive Brokers trade service. They're also not in the "Available Symbols" CBOT futures list.
[2021-10-24 16:10:34] |
Calculus - Posts: 86 |
I'd like those charts as well. Very useful showing the yield instead of price. |
[2021-10-25 15:05:29] |
We will need to add these symbols. Can someone provide us a link on the Interactive Brokers website that contains the specifications for these symbols. We cannot find it.
[2021-10-25 15:56:26] |
This is all I could find. https://www.interactivebrokers.com/en/index.php?f=49778 |
[2021-10-26 05:09:56] |
Sierra_Chart Engineering - Posts: 14224 |
That is not sufficient information.
[2021-10-27 07:38:26] |
UserOne - Posts: 37 |
Re #3 https://contract.ibkr.info/v3.10/index.php?action=Conid%20Info&wlId=IB&conid=511851952&lang=en&ib_entity= Is that sufficient? |
[2021-10-28 15:02:31] |
Yes that is enough. We will set these up. We tried to search for that but could not find it.
[2021-10-29 14:00:20] |
These have been released. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-29 22:25:28] |
Thanks, but the prices are 1000 times too big. For example, the price for the 10Y should be 1.632, but is displayed as 1632.0000
[2021-10-31 20:52:37] |
This is resolved. We did not apply the correct multiplier for the source data from the exchange data. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
