Date/Time: Sat, 11 May 2024 10:59:45 +0000
MATCH NonCLR
View Count: 1069
[2014-03-29 15:34:53] |
Outlander - Posts: 91 |
I used this code in the past but can't get it to work in the nonCLR version? =MATCH(TRUE,AS4:AS900,0) Regards Outlander |
[2014-03-31 05:06:55] |
Due to the complexity of the MATCH function it is not supported in the non-CLR version.
[2014-03-31 06:56:34] |
Ok,that is bad news. It is very useful and I don't know what do to without it? Will you get it to work later? Regards Outlander |
[2014-03-31 07:57:11] |
We made a mistake. We looked at the MATCH function. It will be added if it is not already. It is not a function which takes a formula. It is functions that take formulas that we will not be supporting at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-31 15:08:25] |
Thanks, I am running version 1114.Please let me know then you have fixed the problem? Regards Outlander |
[2014-03-31 17:06:16] |
OK we will do our best to get this done soon, but the non-CLR spreadsheets are still under development. We are actively working on the now though.
[2014-04-01 09:31:06] |
The MATCH function is supported in the non-CLR version at this time. What is the exact problem you are having?
[2014-04-01 11:19:53] |
This code worked =MATCH(TRUE,AS4:AS900,0)in the CLR version but not in the non-CLR version. I get this error #N/A Regards Outlander |
[2014-04-01 17:53:00] |
We will test this and see what the problem is.
