Date/Time: Fri, 03 May 2024 05:01:01 +0000
DOM filter volume
View Count: 426
[2021-10-23 05:31:06] |
AndreyPoroshin - Posts: 102 |
If you set volume filtering in the Chart Setting to exclude a small volume below 25, then when using replay chart, the chart DOM included in the chart is played intermittently, displaying only the volume that appeared on the recent graph above 25. The result is a filtered recent bid / ask volume DOM. It is excellent! But in the case when trading takes place in real time, neither ChartDOM nor TradeDOM is filtered. This is not very logical, since it is not identical in real trading and backtesting. How can I enable filtering in DOM for recent bid / ask volume to be filtered, how is this fine in backtesting? |
2021-10-12_142052.png / V - Attached On 2021-10-23 05:28:29 UTC - Size: 173.45 KB - 134 views |
[2021-10-26 05:00:18] |
Sierra_Chart Engineering - Posts: 14189 |
What you are looking for is not supported.
