Date/Time: Fri, 10 May 2024 04:30:13 +0000
Windows 8 Compatability?
View Count: 1084
[2014-03-29 14:30:06] |
User23815 - Posts: 209 |
I see that your documentation says SC is Windows 8 compatible but has stability issues. Do you still recommend avoiding it? I am upgrading my computer and would like to move to the latest Windows software, specifically Windows 8.1 Pro. Thanks
[2014-03-31 05:08:10] |
Personally, we think Windows 8 will bring the downfall of Microsoft dominance in the desktop operating system market. They have made a gigantic mistake with it, and they have offended a major portion of the user base. I do not have kind words for Microsoft. And we are to be working hard this year to move Sierra Chart on to other operating systems. Windows is no longer considered trustworthy or stable. Also, there can be no doubt the NSA has a backdoor into every user's computer system through windows. At this point, we are not aware of any stability issues, so if you are happy with Windows 8, then go for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-31 05:09:56
