Date/Time: Mon, 29 Apr 2024 21:14:55 +0000
[User Discussion] - Using Macros to Program Reversals
View Count: 541
[2021-10-22 16:49:45] |
User606491 - Posts: 164 |
I find the process of entering reversals via the attached orders window (or via the chart itself) to be extremely clunky. Has anyone figured out if this can be done via macros? Would appreciate some guidance. Thank you, |
[2021-10-30 14:53:42] |
bradh - Posts: 854 |
What part is clunky? The confirmation window? You can turn off confirmations for reversals in the Trade Window Menu. Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific) When you do this, reversals are a single click. |
[2021-10-30 15:04:57] |
Thanks for the bump, appreciate the opportunity to clarify: I don't reverse at market, rather I reverse via stop. Currently, I manually have to change the stop order via the chart to enter a reversal. This is fine in a slow-moving market, which unfortunately is not usually the case when I plan to reverse. |
[2021-10-30 15:08:41] |
I could create a custom study to facilitate this. Send me a Direct Message if interested. BradH |
[2021-10-30 19:30:08] |
Thanks BradH, Will do. |
