Date/Time: Mon, 06 May 2024 02:04:28 +0000
Cannot rollover CLX1 symbol
View Count: 521
[2021-10-22 02:41:34] |
User918591 - Posts: 20 |
Hello, Since monday I cannot rollover CLX1 symbol. I've clicked many timess on "[volume] Symbol needs Rollover.click to rollover" But notting is changing. Here is a screen shot of what I'm talking about. Can you tell me how to correct it? Regards, |
image_2021-10-22_044054.png / V - Attached On 2021-10-22 02:40:56 UTC - Size: 15.36 KB - 123 views |
[2021-10-22 15:26:51] |
John - SC Support - Posts: 31379 |
Please select Chart >> Perform Futures Symbol Rollover. If you still do not get the window for the rollover, then select Chart >> Reset Child Windows and then select Chart >> Perform Futures Symbol Rollover again, and you should get the window to perform the rollover. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-22 16:03:54] |
And be sure to select the next contract month from the Futures Symbol Rollover window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-22 16:04:00
