Date/Time: Fri, 03 May 2024 04:42:33 +0000
TPO
View Count: 429
[2021-10-21 22:23:01] |
User210667 - Posts: 2 |
The two indicators are supposed to have the same value area calculations, but I get two totally different values for each indicator. What's the reason for this? TPO Value Area line Profile chart |
[2021-10-21 22:23:39] |
Both are set at 70% in the settings.
[2021-10-21 22:54:13] |
John - SC Support - Posts: 31334 |
You can NOT set the TPO Value Area Lines on a TPO chart. As you found out, it does not work. Refer to the information at the following link: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart The purpose of the standalone TPO Value Area Lines is to display those lines on a non-TPO chart. Do this and compare the values and as long as the Value Area is the same, you will get the same results. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
