Date/Time: Sun, 05 May 2024 17:05:09 +0000
Removing a separator added through sc.AddACSChartShortcutMenuSeparator
View Count: 610
[2021-10-21 19:23:51] |
User99735 - Posts: 234 |
Hi, How to remove a menu separator using sc.AddACSChartShortcutMenuSeparator? Using sc.RemoveACSChartShortcutMenuItem does not work for separators when called in LastCallToFunction. Regards Vivek |
[2021-12-08 17:10:10] |
Any update on this?
[2021-12-12 16:38:58] |
Sierra_Chart Engineering - Posts: 14234 |
We have not yet had a chance to look into this.
[2021-12-15 04:35:51] |
We cannot reproduce any issue with this. Refer to this function: scsf_ButtonAndMenuAndPointerExample For locating the source code, refer to: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
