Date/Time: Fri, 03 May 2024 18:25:01 +0000
[User Discussion] - HFF - Hidden Force Flux now available for Sierra Chart
View Count: 4825
[2014-05-24 19:55:37] |
User57650 - Posts: 50 |
We have just posted webinar recording from 5/23/2014. Anyone using order flow actively in their trading will likely enjoy the content. Please check www.hiddenforceflux.com under 'WEBINAR' tab.
[2014-06-02 02:53:09] |
We have scheduled our next webinar for 6/5/2014. Please check www.hiddenforceflux.com for details. We will be looking at HFF basic rules to follow. |
[2014-06-05 20:44:10] |
We have just posted today's webinar recording (6/5/2014) on HFF Basic Rules To Follow. Please check www.hiddenforceflux.com under 'WEBINAR' tab.
[2014-06-05 22:46:08] |
Just letting you know, that we are going to be releasing the change to DTC that changes volume, quantity, and size structure members from integral types to floating-point types. This is DTC version 4. It will be out next week. It will be a prerelease. You should just need to recompile against the provided header file and this is all. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-06 01:22:09] |
Thank you for that note, I will be watching for that release. In our case, it will require to change some fields in the 'translated' C# header file as we read the message structures received from the socket based on what types appear as their member variables. It should be quite straightforward though.
[2014-06-06 03:23:04] |
Yes, we do expect it to be straightforward.
[2014-06-06 04:13:26] |
If you would like to get a head start, you can work on the changes using this release: https://www.sierrachart.com/downloads/SierraChartSetupDTC4.exe Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-07 02:53:40] |
Great, thanks. I already updated the relevant 'translated' message structures and did some limited testing. So far everything working just fine.
[2014-06-16 12:20:36] |
We have scheduled our next webinar for 6/19/2014. Please check www.hiddenforceflux.com for details. We will be looking at HFF replenished volume. |
[2014-06-19 02:19:59] |
Thanks for the suggestion, I didn't even know this was an option. We have not posted anywhere else so far though. In our webinar tomorrow, we will cover some interesting situations in CL and GC (regarding replenished volume).
[2014-06-21 02:58:23] |
We have posted yesterday's webinar recording (6/19/2014) on HFF Replenished Volume. Please check www.hiddenforceflux.com under 'WEBINAR' tab.
[2014-06-23 19:18:05] |
We have updated our software to accommodate the new version (4) of DTC protocol. All Sierra Chart users should now be using Sierra version >= 1145 with the newest version of HFF software. We have also added new audio/visual alerts for replenished, swept and algorithmic volume.
