Date/Time: Mon, 29 Apr 2024 17:41:55 +0000
Cumulative Delta Bars by Volume reset
View Count: 1158
[2014-03-28 22:46:41] |
User87197 - Posts: 65 |
Hey guys, it would be really great if the cumulative delta bars by volume had an option of resetting every month instead of just the "Reset at start of trading day" option that it currently has. If this implementation would be possible it would be greatly appreciated. Many thanks!
[2014-03-29 00:02:58] |
You can do this by just loading one month of data in the chart through the Chart >> Chart Settings >> Use Date Range / Use Number of Days to Load We will not be adding the option to the study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-29 00:40:44
