Date/Time: Tue, 07 May 2024 01:21:45 +0000
Trades Tab - Profit/Loss based on Globex open
View Count: 373
[2021-10-19 03:04:01] |
DayTraderEsad - Posts: 116 |
Is there any way where I can manipulate the order fills (exits) to show/mimic what my broker Dorman has in their statement. When I run a performance to see what I made each day, it does not match what Dorman has. Since the cut off is at at the close for current day, and then the next day starts at Globex open for the broker daily statements. Sierra performance data shows it based of a normal calendar. Which considers it the same day till midnight. I'm just asking if the days start time can be started at Globex open instead of midnight. I hope that makes sense
[2021-10-19 09:13:08] |
Yes this is definitely controllable and explained here: Trade Activity Log: Understanding Daily Trade Statistics Reset Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-19 13:36:22] |
When you export the trades data it shows the days such as 10/18 @ 1800 -- even with that trade time in Advanced setting 3 being set to Globex open. How can I have the 10/18 show 10/19 date in the export of the trade data from the trades tab?
[2021-10-19 14:04:13] |
The order fills will always have the exact date and time of the fill. When you do an export this will be in UTC. If you do Save Log As, the time will be as it is in the Sierra Chart time zone.
