Date/Time: Sun, 11 Oct 2026 08:06:20 +0000
Multiple studies in same region?
View Count: 1545
| [2014-03-28 15:41:53] |
| bwalks123 - Posts: 122 |
I am attempting to set the On Balance Volume study and A 21 period Weighted Moving Average in the same chart region but am having scaling issues. I have both set to region 2 and scales set to independent but when I zoom the chart either in or out the weighted moving average starts dancing around inconsistently to the On Balance Volume study? I see that there is a On Balance Volume with moving average study built together but I believe that is using a Simple Moving average and I am needing a Weighted Moving average. Any help would be great. Thanks |
| [2014-03-28 18:05:28] |
In this particular case, you need to set the Scale Range for each of these to "Automatic". Assuming they have similar scales.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-28 18:27:58
| [2014-03-28 18:05:55] |
| vegasfoster - Posts: 444 |
Set both scales to automatic.
