Date/Time: Mon, 06 May 2024 19:33:10 +0000
external data feed connection not possible
View Count: 1429
[2014-03-28 15:31:04] |
Eliska Petraskova - Posts: 4 |
Starting TWS auto-login thread. | 2014-03-28 16:22:44 TWS auto-login thread ending. | 2014-03-28 16:22:44 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-28 16:22:46 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-28 16:22:47 Socket has been shutdown and closed. | 2014-03-28 16:22:47 Failed to connect to the data and trade server. | 2014-03-28 16:22:47 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-03-28 16:22:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-28 16:22:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-28 16:22:47 Disconnected from IB. | 2014-03-28 16:22:47 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-28 16:22:47 Starting TWS auto-login thread. | 2014-03-28 16:22:48 TWS auto-login thread ending. | 2014-03-28 16:22:48 Starting TWS auto-login thread. | 2014-03-28 16:22:52 Interactive Brokers: Connecting to 127.0.0.1:7496 | 2014-03-28 16:22:52 TWS auto-login thread ending. | 2014-03-28 16:22:52 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-03-28 16:22:53 Socket has been shutdown and closed. | 2014-03-28 16:22:53 Failed to connect to the data and trade server. | 2014-03-28 16:22:53 Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2014-03-28 16:22:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-28 16:22:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-28 16:22:53 Disconnected from IB. | 2014-03-28 16:22:53 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-28 16:22:53 File >> Disconnect selected. | 2014-03-28 16:22:54 Disconnected from IB. | 2014-03-28 16:22:54 I have already filled the account name and password for Interactive Brokers as advised and it still doesn¨t work |
[2014-03-28 16:31:53] |
Sierra Chart - Max - Posts: 5607 |
Make sure you have setup Sierra Chart for IB properly by following steps here: https://www.sierrachart.com/index.php?l=doc/IB.php#SetupInstructions Sierra Chart Support |
[2014-03-28 17:19:16] |
Go through the IB set up instructions here: https://www.sierrachart.com/index.php?l=doc/IB.php#SetupInstructions Sounds like Trader Workstation might not be running? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
