Date/Time: Thu, 02 May 2024 01:24:47 +0000
renko chart
View Count: 1527
[2014-03-28 15:00:06] |
User45440 - Posts: 2 |
Hi, I just newly open trial account with sierra,and i try to setup charting with renko bricks, the renko bricks and renko brick with wicks is not showing at all, and actually i'm renko trader, so how can i get activate this renko mode, please help me setup my charting thanks in advance Date Time Of Last Edit: 2014-03-28 20:20:57
[2014-03-28 18:11:12] |
vegasfoster - Posts: 444 |
http://www.sierrachart.com/index.php?l=doc/doc_RenkoCharts.html Make sure you have also changed to bar period to Renko Charts and set the size of the bars. |
[2014-03-28 20:20:30] |
Here is the documentation for Renko charts: http://www.sierrachart.com/index.php?l=doc/doc_RenkoCharts.html If you still need help, we need to see an image of the chart. Follow these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-29 04:37:29] |
Thanks for kind reply, I have gotten the renko charts according your info, here I have another issue, Please find the attached file, and there in the renko i given input 10 points per box, and the renko box shows some different come places, any solution please thanks in advance abdul |
data feed error in the chart.png / V - Attached On 2014-03-29 04:31:40 UTC - Size: 117.41 KB - 410 views |
[2014-04-03 06:56:33] |
We apologize for the delay with this. This needed some time for review and documentation updates. We have added this to the documentation: The body of the Candlestick, from the Open to the Close, is based upon the size of the bricks which is specified in ticks. For example, if the Tick Size for the chart is .25 and the brick size is 4 ticks, then the body/brick will always be 1.0 in length. The body can be cut short if New Bar at Session Start is enabled in Chart >> Chart Settings.
It looks as though some of the bricks might be little longer than the setting, this might have to do with not having tick by tick data: https://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
