Date/Time: Sat, 04 May 2024 07:12:09 +0000
Chart that charts Bid ask at very front and prints price right behind it?
View Count: 523
[2021-10-18 01:41:28] |
User220914 - Posts: 239 |
Hello, if you jve had a look at CQG charts they actually chart the traded prices however they chart the bid ask on the exact same chart at the beginning of the chart as it is scrolling and as the bid ask changes. so you get almost a hybrid chart where the current and rapid bid ask spread is being charted and every time an actual trade happens the same chart prints or charts that traded prices while the beginning of the chart or fartehrs on teh right side as it is scrolling in real time is the Bis ask is this possible in Sierra chart? |
[2021-10-18 15:12:28] |
John - SC Support - Posts: 31362 |
The easiest way to see the Best Bid/Ask prices is to add the Recent Bid Volume and Recent Ask Volume columns to the DOM. Then ensure that the Graphics Settings for Chart[Trade] DOM Recent Bid Best Bid Background and Chart[Trade] DOM Recent Ask Best Ask Background are enabled and set to colors you desire. Also, ensure that the graphics options for Chart[Trade] DOM Last Traded Recent Bid Volume Background and Chart[Trade] DOM Last Traded Recent Ask Volume Background are not enabled, or the colors will get confusing. Although if you want them this way, then that is an option. If you are looking for something else, let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-19 01:28:57] |
For reference for the above, refer to: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Also have a look at using this Study: Bid & Ask Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-19 01:29:43
