Date/Time: Thu, 02 May 2024 04:42:11 +0000
Session Start/End times. Default settings changes
View Count: 459
[2021-10-17 11:14:16] |
User92573 - Posts: 483 |
Dear Support I can change chart session times manually via chart settings however the default for new intraday charts seems to have changed and for some reason I am getting 11:00:00 to 00:59:59. Bund Data images attached as example along with SC Time zone settings. Current System time UTC +00:00 Have I changed a setting in error? Many thanks |
Chart Settings.png / V - Attached On 2021-10-17 10:48:31 UTC - Size: 7.59 KB - 113 views Data Settings.png / V - Attached On 2021-10-17 11:04:41 UTC - Size: 31.22 KB - 114 views Time Zone Settings.png / V - Attached On 2021-10-17 11:13:14 UTC - Size: 7.05 KB - 132 views |
[2021-10-17 16:32:09] |
John - SC Support - Posts: 31293 |
This has not changed any time recently, those start/end times are what has been set for a long time. You can always change the Symbol Settings to have the Start/End times as you want them to be. Refer to the following: Global Symbol Settings: Setting of Intraday Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
