Date/Time: Mon, 29 Apr 2024 09:28:10 +0000
Accessing "Quantity" From the DOM
View Count: 463
[2021-10-15 18:10:31] |
Joel Wisdo1 - Posts: 15 |
Is there a way to access the "Quantity" from the DOM so I can update the number of contracts in my auto-entry from the DOM?
[2021-10-16 10:50:42] |
User515920 - Posts: 7 |
I've posted a screenshot below highlighting where to click in order to change quantity from your DOM. I hope that answers your question!
domquantity.jpg / V - Attached On 2021-10-16 10:46:29 UTC - Size: 23.58 KB - 119 views |
[2021-10-17 16:04:20] |
Refer to the following documentation for ways to change the Order Quantity: Chart Trading and the Chart DOM: Changing Order Quantity If you are using a custom study, then the order quantity is available through ACSIL. Refer to the following: ACSIL Interface Members - Variables and Arrays: sc.TradeWindowOrderQuantity Also, you can set the order quantity for a trade within ACSIL. Refer to the following: Automated Trading From an Advanced Custom Study: [Type: integer] s_SCNewOrder::OrderQuantity And finally, the order quantity can be read/modified on the Spreadsheet Study at the following cell: Spreadsheet Systems, Alerts and Automated Trading: Order Quantity [J26] For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
