Date/Time: Mon, 29 Apr 2024 05:35:43 +0000
TPO Merged Profile Indication/Marker
View Count: 1131
[2021-10-14 15:40:16] |
wagerfield - Posts: 1 |
Is there anyway of indicating/marking that 2 or more TPO profiles have been merged? When I merge TPO profiles together, the only way I know that they have been merged is by right clicking on them and seeing if any of the un-merge options are available. I have read the TPO docs and searched the Support Board and Google and the only thing I could find was a previous Support Board post asking the same thing: TPO Profile merge Something like the "Highlight Open In Profile" setting but highlighting the Open of EACH MERGED PROFILE would be ideal! Thank you for your time and consideration. |
[2021-10-14 16:55:50] |
There is not a way to distinguish merged profiles. We have set this as a Feature Request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-23 06:32:31] |
AKR - Posts: 523 |
am also interested in that. is there something available meanwhile?
[2022-08-23 09:30:29] |
Sierra_Chart Engineering - Posts: 14126 |
What we are going to do in the next release is support a Profile Value Label that will include the period ending and also the time span of the profile. There is also the Period Start. More information: Time Price Opportunity (TPO) Profile Charts: Chart Value# (1-4) To Be Displayed On Profile By looking at these values, you will then be able to tell if there is a merge or split. Later on we can look to see if we can display the word Merge or Split to denote these conditions. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-23 10:11:02] |
Here is an example: https://www.sierrachart.com/image.php?Image=1661249272855.png The profile on the far left, is three one-day profiles merged into one. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-22 09:18:42] |
AKR - Posts: 523 |
would it evt be possible to change the "period time span" (which is great to have) so that it does show full days only. so what I mean is I eg only look at RTH sessions on TPOs. when I merge two of them it shows me 32,5 hours. and similar later on. What I would like to see is just 2 days. and 3 days, 4 days etc. Date Time Of Last Edit: 2022-09-22 09:45:23
[2022-11-10 07:44:37] |
AKR - Posts: 523 |
so that means no?
[2022-11-10 12:31:20] |
We will see what can be done.
[2023-05-14 23:49:24] |
Technical - Posts: 148 |
Can you provide a chartbook with this display function enabled as an example?
[2023-05-15 06:48:42] |
AKR - Posts: 523 |
Like here. This is two full RTH sessions. what it shows is 32.5 hours. I would prefer to see just 2days or 2d or so. Gets though more complicated when sessions are split like example two with 27.5 hours. At the time I did start the post tbh I did not think about splits. |
Screen Shot 15.05.2023 at 08.44.png / V - Attached On 2023-05-15 06:44:42 UTC - Size: 15.71 KB - 71 views Screen Shot 15.05.2023 at 08.46.png / V - Attached On 2023-05-15 06:48:29 UTC - Size: 18.64 KB - 71 views |
[2023-11-16 01:03:37] |
joshtrader - Posts: 439 |
I would like to second this request and report a behavior that is probably undesirable for most people. I have my TPO period as "1440 minutes" to get a single bar per day (I do this so I can attach a VbP and use the TPO functionality to merge volume profiles). When I merge Friday and Monday profiles, the PTS shows this as "4d" as it counts Saturday and Sunday. Combining Monday with Tuesday correctly gives the PTS as "2d". Just something to consider, thank you.
[2023-11-16 07:21:56] |
AKR - Posts: 523 |
Agree I dont like that either and I have had a similar request on that long time ago.
