Date/Time: Sun, 28 Apr 2024 17:34:40 +0000
SC Order Routing with 2 diff live accounts
View Count: 413
[2021-10-13 18:23:23] |
garytrader12 - Posts: 2 |
Hello, 1) Can I use the same SC account and SC Order Routing to trade 2 different live accounts , one with Phillips-Edgeclear and 2nd one with Advantage-Stage5 ? If yes, can I do it using the singe instance of SC OR will I have to install a second instance and in the DTS settings, use Phillips acct with SC instance1 and AdvAcct with SC instance 2 ? 2) If yes to 1 ), I will pay for SC Pkg 10 ONLY once, correct ? 3) What about CME top of book data with Denali ? Will I have to pay CME top-of-book fees twice , one for each live-trading account ? Thank you |
[2021-10-13 23:28:12] |
1. The older Sierra Chart order routing service based on TT does support this in a single instance. The new version of the Sierra Chart order routing service requires separate instances of Sierra Chart. You can use the same Sierra Chart account. 2.Just once. 3. Just one exchange fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
