Date/Time: Sat, 27 Apr 2024 21:29:51 +0000
Information: Config TPO
View Count: 587
[2021-10-13 18:14:16] |
User428917 - Posts: 4 |
Hello. I want to put my market profile in Brussels (+2) 00:00:00 23:59:59. How to configure the "A" of the TPO to start at 8am when we set a session start at 00h on Sierra? Thank you
[2021-10-13 18:24:48] |
To do this you would need to determine the number of periods from 00:00 to 08:00 for your TPO and then change the lettering order such that A starts at the number of periods specified. For example, if you are using 30 minute periods, then there would be 16 periods between 00:00 and 08:00. Therefore, you would want the 'A' to be the 16th letter in the TPO Letter Sequence. Refer to the following: Time Price Opportunity (TPO) Profile Charts: TPO Letter Sequence For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
