Date/Time: Wed, 08 May 2024 19:28:05 +0000
2 charts
View Count: 912
[2014-03-28 03:16:42] |
User28682 - Posts: 233 |
Hi all, I am wondering if one can have two symbols on the same chart? Example: ES on top, TICK-nyse below it. Thanks, Tom |
[2014-03-28 10:12:04] |
Yes. Refer to: http://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php#Overlaying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
