Date/Time: Fri, 03 May 2024 21:07:39 +0000
[Programming Help] - Spreadsheet_alert ONLY once
View Count: 338
[2021-10-12 17:11:55] |
User291209 - Posts: 2 |
Hi Sierra, I would like to ask you if you can help me in the following issue. I created an alert with three conditions (all three gives 1 if condition is met). In order to notify me only in case all 3 conditions are met, I coded the following in Q3 cell: =(L3+N3+P3)=3. That's working fine. What I would like to achieve is that I want to be notified ONLY FIRST TIME if all conditions are met. In most cases I receive alerts several time after first time, which means that my phone is beeping a lot, unnecessarily. Hope you can provide me some useful advice how to set it up. Many thanks in advance. Regards, Tamas |
[2021-10-12 20:10:31] |
Sawtooth - Posts: 3993 |
Try this in column R: =AND(Q4=0,Q3) This moves the alert to column R, since it finds only the first time Q goes TRUE. |
