Date/Time: Sun, 19 May 2024 02:33:52 +0000
qty is 1: dom did 2: why?
View Count: 339
[2021-10-12 15:17:01] |
User266838 - Posts: 13 |
when i hilight trade activity log starting at 2021-10-12 09:57:56.525097 #12524 i do a right click hoping for a copy & paste,,,,,,but it wont work either... grrrr .. how do i help you now? can you see it from your end? What went wrong as i keep getting these wrong qty orders that i dont want with real money. Thx so much for helping me. darwin |
[2021-10-12 17:11:54] |
To copy the lines from the Trade Activity Log, select the lines to have them highlighted, then select Edit >> Copy Selection. Please paste the lines into this thread and give us more information on what exactly is the problem. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-12 19:34:56] |
Also refer to: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
