Date/Time: Sat, 27 Apr 2024 18:23:13 +0000
socket remotely closed with HSIV1
View Count: 425
[2021-10-12 15:10:27] |
User576595 - Posts: 14 |
cant get real time up dating with this instrument pls hv a look thanks |
[2021-10-12 17:08:02] |
Our servers are showing that your Current Selected Service is set to SC Data - All Services. If this is correct, then HSIV1 is not the correct symbol. It would be HSIV21-HKFE. You an change the symbols by selecting Edit >> Translate Symbols to Current Service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-15 03:06:21] |
still not working my friend! :( |
Screenshot 2021-10-15 092456.png / V - Attached On 2021-10-15 03:05:53 UTC - Size: 57.19 KB - 117 views |
[2021-10-15 04:53:14] |
its been reactivated from your end thanks |
