Date/Time: Mon, 06 May 2024 17:20:42 +0000
Charting SPX
View Count: 721
[2021-10-12 02:33:13] |
kulu - Posts: 1 |
Hi, Is it possible to chart SPX with Denali and Sierra? Is the symbol for SPX SPX500? Thanks |
[2021-10-12 15:55:53] |
John - SC Support - Posts: 31401 |
In order to get the true SPX you would need to use the Sierra Chart Exchange Data Feed and activate the S&P Indices exchange. For more information, including Setup Instructions, refer to the following: Sierra Chart Exchange Data Feed The symbol is going to be in this case $INX. The SPX500 is the CFD of the index. It can be used as a substitute, just be sure you understand what it measuring and how you should view it in relation to the $SPX. Refer to the following: Sierra Chart Real Time and Historical Forex and CFD Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-12 17:30:39
