Date/Time: Sat, 18 May 2024 12:47:02 +0000
Can you restore Sim trading data
View Count: 418
[2021-10-11 21:30:09] |
Phil K - Posts: 1 |
Hi, I was using the chart replay function and accidently clicked on "Clear All Trade Data for Symbol and Account" is there any way of getting the trade data back for my sim please? Thanks. |
[2021-10-12 01:50:51] |
Backups are made, when that operation is performed. They are in the Backups subfolder in the Sierra Chart installation folder. This is an example file name: 2021-10-12 014240.TradeActivityLog_2021-08-27_UTC.Sim1.simulated.data You will want to exit from Sierra Chart, move these files back into the TradeActivityLogs subfolder in the Sierra Chart installation folder, and remove this Date-Time portion: 2021-10-12 014240. If the files already exist in the destination, then delete the ones that are there because they will be empty. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
