Date/Time: Sat, 04 May 2024 20:24:59 +0000
Feature request like Journalityx.
View Count: 714
[2021-10-11 18:39:28] |
Spartan79 - Posts: 54 |
Any plans to expand trade activity log to the level like Jigsaw's Journalityx or Tradervue? Where we could visualize the numbers and many stats already there in form of charts and graphs. For one it's easier to see and work with the stats. Also the ability to tag or name different setups/trades is a must. One thing that's really annoying now is that we have to export the trades manually to excel or other services like that. It could be in SC or web based. I know that you are extremally busy now with adding other exchanges and SC order routing. But is there possibility that you can consider implementing that sometime in the future? Thank you. |
[2021-10-12 14:44:47] |
John - SC Support - Posts: 31362 |
It is not something that we will be getting to anytime soon, nor do we have any specifics, but we have discussed expanding the journaling capabilities of the system.
[2021-10-12 16:08:24] |
OK thank you. Is there possibility of adding tag system to name the different trades setups at first and build from there? |
[2021-10-12 17:52:47] |
There is an ability along these lines that already exists, which is the Text Tag. Refer to the following: Basic Trading and the Trade Window: Set >> Text Tag For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-29 15:53:04] |
Any update on this? Any timeline when we can expect to see expanded journaling capabilities, or at least improved Tag system? Thank you. |
[2022-11-29 01:42:49] |
User624595 - Posts: 183 |
Some small improvements would go a long way to improving trader/performance analytics in Sierrachart: -Enable the Text tag to be available on the Compact view of the Trade window. -Text tag selected via a dropdown, independent of the Trade Window Configuration file. -Edit and Assign Text tag after the fact (correcting issues where it's not properly recorded on both entry and exit). -Assign more than one Text tag, even two or three would add a lot of flexibility to trade analysis. |
