Date/Time: Thu, 02 May 2024 07:52:55 +0000
Data not downloading into spreadsheet
View Count: 1131
[2014-03-27 18:04:21] |
rhovega - Posts: 279 |
Hi Sierra, I need help please. Trying to download a full year of historical data into a spreadsheet. I can't. I do the following: 1. open historical chart 2. make it show data since 2009 (more than I need, just in case) 3. delete all data and download (to re-download the data, just in case) 4. open spreadsheet study Problem: it is only showing data since 2014. Pls note the chart settings has 4380 days to display/load, and the data settings has 500 max historical days to download. I am using Sierra/FXCM's data feed for this. Please help. Thank you GK |
[2014-03-27 18:08:05] |
In the Study Settings window for the Spreadsheet study, you will see an input named Number of Rows. You need to increase this. Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
