Date/Time: Mon, 06 May 2024 20:26:37 +0000
P&F chart
View Count: 1111
[2014-03-27 17:16:42] |
TradingMarketProfile - Posts: 120 |
Hello, When i add P&F chart, there is hole in the chart with no data ( as you can see on the picture) and it's with all symbols http://www.sierrachart.com/image.php?l=1395940443598.png |
[2014-03-27 17:26:26] |
We do not understand from this image what you are referring to.
[2014-03-27 17:34:21] |
All the vertical line are the hole in the chart, there is no data and big space between the bars
[2014-03-27 17:38:24] |
With P&F :http://www.sierrachart.com/image.php?l=1395941832779.png Without : http://www.sierrachart.com/image.php?l=1395941863229.png |
[2014-03-27 17:46:04] |
When using the Numbers Bars study, it does not work well with Point and Figure charts and we do not provide support for that. Instead use "Reversal" bars through Chart Settings. Refer to this section here about Reversal bars: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-27 17:48:34] |
We still do not understand what you are referring to with the additional images. You also have put a Point and Figure study on a Reversal bars chart. This is really confusing things. We are not going to provide support for that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-28 05:42:12
[2014-03-27 17:49:36] |
ok thanks
