Date/Time: Sat, 18 May 2024 17:29:49 +0000
Can't delete symbol
View Count: 465
[2021-10-08 14:08:11] |
The Stealthy Trader - Posts: 162 |
For some reason I can't delete SPRT from my Data folder and am tired of seeing it appear every time I do a scan. I don't recall having this issue when deleting other symbols. Please help.. |
[2021-10-08 16:33:42] |
The first thing is to ensure that Sierra Chart is not running. You should not have a problem deleting the file as long as the program is closed.
[2021-10-10 03:06:05] |
Refer to: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-10 03:06:43
[2021-10-11 11:45:57] |
Got it..I had the symbol open in another chartbook that was always open..seems to be resolved now..thanks again
