Date/Time: Tue, 07 May 2024 04:49:33 +0000
PROGRAMING WITH ACSIL
View Count: 1375
[2014-03-27 14:02:57] |
User82615 - Posts: 106 |
HELLO COULD ANYBODY TELL ME IF IN PROGRAMMING A TRADING SYSTEM IF THERE IS ANYWAY OF USING "OR" WHEN PROGRAMMING A CONDITION IN THE TRADING SYSTEM THE SAME THAT IT USES "AND" USING "&&" . FOR EXAMPLE I WOULD LIKE TO PROGRAM A CONDITION IN MY SYSTEM THAT SAYS THAT I WANT TO ENTER A TRADE IF A BAR CLOSES ABOVE A MOVING AVERAGE OF 10 "OR" IF THE BAR CLOSES ABOVE THE MOVING AVERAGE OF 200. IS THIS POSSIBLE TO DO USING ACSIL? THANK YOU |
[2014-03-27 18:35:45] |
vegasfoster - Posts: 444 |
|| represents or This is a good resource for learning the fundamentals of C++ http://www.cplusplus.com/ |
[2014-03-27 19:16:24] |
Here is the reference for logical operators you can use: https://www.sierrachart.com/index.php?l=doc/doc_cpp_Operators.php#LogicalOperators Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
