Date/Time: Fri, 03 May 2024 22:14:05 +0000
Doesn't work real time data for ICE BRNZ21 data from 06 October
View Count: 577
[2021-10-06 17:52:50] |
User345988 - Posts: 5 |
How can I add all interruped data to the charts? Edit/Dowload data - Intraday charts doesn't work. There are no data on your server for period of interruption. Please upload it. |
[2021-10-06 18:27:57] |
John - SC Support - Posts: 31362 |
Can you please give us a screenshot of what you are seeing so we can better understand what you are missing. Refer to the following for how to attach a screenshot: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-06 18:55:05] |
http://www.sierrachart.com/image.php?Image=1633546371185.png
[2021-10-06 23:49:32] |
What are your chart session times and what is the time zone for the chart?
[2021-10-07 05:29:32] |
Time zone - Moscow Time (GMT + 3). Session time - 2:00 - 1:59.. No data from 3:00 till 14:19 msk time on 6 Oct 2021. You wrote that this time you have problems with Barchart provider from ICE data stream. Certainly this period can’t download with function of delate and dowload intraday data from this point. |
[2021-10-07 05:48:08] |
http://www.sierrachart.com/image.php?Image=1633585676194.png
[2021-10-07 09:51:29] |
We are having issues patching the missing historical data assuming it is even available from Barchart. Allow about one more day for us to get this resolved assuming the data is available.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-07 09:51:47
[2021-10-21 19:08:33] |
Still doesn't work. This is the most expensive data. Holes in data stream distort trading models.
Date Time Of Last Edit: 2021-10-21 19:11:11
[2021-10-21 20:56:06] |
If you are referring to recently missing data, then can you please get us a screenshot showing where you are missing data. To get us a screenshot, follow these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-22 19:46:44] |
Sierra_Chart Engineering - Posts: 14205 |
The problem is our data provider Barchart is missing this data. We could recover the data from another source but this is a more involved procedure. And we do apologize for the delay. We also plan to discontinue offering ICE data directly through the SC Exchange Data Feed at the end of December 2021. Look at using IQ Feed for ICE data after this time: DTN IQ Feed Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-10-22 19:47:29
