Date/Time: Fri, 03 May 2024 08:45:13 +0000
sc historical and intraday data....
View Count: 911
[2014-03-27 03:53:09] |
User53765 - Posts: 66 |
Hi Support, I recently tried to access the sc historical and intraday data looking up past ES symbols but nothing was registering like it used to. Im not connected to CTS at the moment but was wondering why at least the SC symbols are not showing up like before when I had tried the same thing. Thanks in advance. |
[2014-03-27 07:15:27] |
You need to use the service named "SC Historical Data": https://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html This service has now been updated to provide historical tick by tick data, if that is what you are looking for. Although for that to work you need to be updated the very latest Sierra Chart version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-27 07:15:48
